JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Sat Jul 12, 2003 10:17 am
What type of refrigerant do you use? This is important to consider, since R12 is like $72 a pound (my 90 takes 2 pounds) and is not available in a lot of areas, while R134A is like $20 a pound. A/C work can get expensive fast. More than likely you will wind up retrofitting to R134A, replacing the reciever/dryer, as well as the compressor. Then you have to flush the R12 out before you charge it with R134A.
