12Ounce »
https://forums.nicoclub.com/12ounce-u52716.html
Fri Jan 19, 2007 2:57 pm
NOISEY NEWLY OVERHAULED KA24E IN A 1993 PICKUP!
I just, an hour or so ago, finally finished up an overhaul on my 1993 Pup. With the hood still removed, and the truck under a low carport, the engine was run for less than two minutes. Started right up. From the start, it makes considerable noise from the rocker/cam area. But I may not know what to expect ... and it may be normal noise level ... but certainly louder than a Ford four banger that I overhauled a couple of months back.
I did the overhaul labour on the engine bottom, but had a specialty shop rebuild the head. Got rebuilt rockers, shafts, resurfaced valves, etc ... and a new set of lifters. I made no effort to pre-primed the lifters ... could this be the noise-maker?
I did pour oil over the cam, rockers and chain drive. I hand primed the oil pump and then cranked the engine without plugs 'til the oil-light went out. All this before starting up the engine.
When the engine was idling, I peeked inside the oil-fill hole. Seems to be plenty of oil splashing about. But tomorrow I may hand-crank the engine and see if oil is coming up to the cam/rocker area.
Any thoughts??
Modified by 12Ounce at 6:10 PM 1/19/2007
