from hijackers rebuild thread:
Installing the Hydralic Lash Adjusters is the next step. First, you should bleed them as you have easy access to them, and we all hate the sound of ticking lifters.
Proper shimming of the head requires that you place the rocker arm guide, which is the shim with the center cut out of it on top of its valve, and then use a dial gauge to measure the distance from the top of the guide to the top of its adjoining valve stem. Nissan requires a special dial gauge stand to make this work, and that stand is pretty much impossible to find anymore.
There is hope, though. Custom Steel makes a dial gauge tool.
It's not cheap at $175, but considering that you have your head shimmed properly, the price seems worth it. Especially if you and your friends build SRs often enough. Email Pat at
[email protected] to order. His turn around is about 2 weeks from receipt of payment.
it's up to you, but i strongly recommend you pull that head apart and bleed the lifters. he does mention a bit later that most people don't bother checking the shims, and for $175 I can't say I blame them too much, but it will be better.
diy-rebuilding-an-sr20det-t309576.html
