Rockhound »
https://forums.nicoclub.com/rockhound-u65977.html
Sun Jan 20, 2008 1:57 pm
If you're not too afraid to dig into things, you can find ways to eliminate most of the noises yourself. I've never torn into an almost new car, mind you, but like others have said, when most of the interior parts are plastic, these noises are (almost) unavoidable.
I'd recommend buying some felt cloth and some various foam pieces that you can trim down into manageable chunks and wedges. Most of the plastic-on-plastic seams will be the culprit, of course.
The shift surround on my G20 did the same exact thing - it would creak on corners when the car was flexing. So I disassembled the center console and lined various parts with thin craft foam and felt, everything fit together snugly and there was less plastic/plastic contact between parts.
If you're having trouble locating a noise, take a buddy along to drive or ride with you to help locate problem spots...
