Crank the radio.....
Seriously youll never* get them all. When you think you have found them all, just then, a new one pops up. I got rid most, but still have a cpl annoying ones, and some come and go types (like my horn pad).
One I just fixed was comming from the vent area. Frustrated and doing 85mph, I ripped out the center vent trim peice, and located the noise (i was really irritated by it). It was comming from under the ac controll unit. The unit has thin plastic lossly in place at both the top and bottom. I took some duct tape (hehe used duct tape for ac like its meant
) and placed it at the top and wrapped it down to the bottom tightly. It stopped the plastic from resonating and rattling though.
I wrapped weater stripping on the parts of the door panel that contacts the metal and a few small peices around it as well. That removed those, but I crackedthe plastic connector holding the handle / window controlls on the passenger door, one side of the plastic U. urg gotta fix that now.
What sucks the most is that all my rattles come on at different rpms as my exhaust emits different res freq's at different rpm's. If it was all at once that would be fine as I would just slow down or speed up, but NOOOOO.
Also all my clips in most of the panels are rtv'd in place hehe.
*There is one sure fire way, but its costly and ruins the 240. That is completely covering the cars inner shell in sounddeadening material. At least one layer would help but if I went this route I would go 2 layers. It would weigh a ton but would be as quiet as a luxury car. Up side is that there would be no rattling and your stereo would sound alot sweeter.
