stoictwo »
https://forums.nicoclub.com/stoictwo-u199789.html
Sat Mar 03, 2012 4:05 pm
My first post- I have a 2004 G35 coupe, non - brembo brakes. When gently applying brakes at basically any speed, there is a repetative "knocking " noise on the driver's front. It is not severe, it goes away with a little more brake pressure, it does not really make the steering wheel shake, nor does it make the brake pedal pulsate like a warped rotor. I just replaced the left lower front control arm because the bushing was bad, and this helped lessen the noise for the better. I next tried new caliper pins because it seemed like there was too much wobble when I manually rocked the caliper. This also helped lessen the noise slightly even though the "rocking" feels the same. There does not appear to be any other bad bushings or links that I can see or feel. Could the bracket be bad that the caliper pins ride in ? I want to re-state that the noise is an irritant more than a scare, and the "window" it happens in is small but happens with everyday driving.Thanks for any suggestions.
