Noise when reversing
dieselab
does anyone have this problem or have any idea what is going on?
corn322
Car: 1993 240sx
"the reverse noise"
it's the way the gears are cut, they just whine like that.
unless you're talking about something else
Goodbar6
Kind of a groan noise? Only every once in awhile? Get your rear brake rotors turned at a local parts store. The sound tends to come from warped rotors.
dieselab
hard to explain the noise..happens when i am in reverse or when the car is rolling backwards by itself
S13240
Haha..I get that too...I've gotten use to it though. :pface
Scott McLellan
I had the exact same problem. Turns out whoever did the brakes last messed up the back left caliper. The inside brake pad has a little metal pin (or two? can't remember) on the back that HAS to be lined up with the slots in the piston. These are the 4 slots that allow the use of a tool to turn the piston back into or out of the caliper. Mine wasn't allined and the pad sat in there crooked causing it to wear uneavenly. When I would back up in or out of gear that pad would bind causing the noise.
allens 240sx
Car: Basketball, hooking up the 240 and hanging out.
if the problem is like a loud rubbing sound, all i had to do is replace my back brakes, it turns out the ones that were on there were a little worn out, so i slapped on some new raybestos and that solved the problem for me..
vwluv10338
Scott McLellan wrote:I had the exact same problem. Turns out whoever did the brakes last messed up the back left caliper. The inside brake pad has a little metal pin (or two? can't remember) on the back that HAS to be lined up with the slots in the piston. These are the 4 slots that allow the use of a tool to turn the piston back into or out of the caliper. Mine wasn't allined and the pad sat in there crooked causing it to wear uneavenly. When I would back up in or out of gear that pad would bind causing the noise.
I have the noise too and I am pretty sure you hit the nail on the head. I am pretty sure that is the problem because I am the one who did the brakes and I had a problem lining up those slots. I had the same problem on the front and sometimes I can hear the pads drop into the slots if I go slow and lay on the brakes slow and hard. Part of the problem I think was also that my shims were all rusted in half and the parts stores around here didnt have them so I am running shimless on all 4 brakes.
Eric
