noise when over bumps.....
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
there is a noise that comes from the driver side tire when i go over bumps, it is a metal sound, i was thinking that it was the tie rod, so i replaced the driver side tie rod over the weekend, which improved the steering, but the sound is still there, any suggestions on what i should check thank you
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
How are your sway bar bushings and end link?
Big Tone
Car: 1993 Infiniti J30
I have the same issue and am in the process of getting my tie rods replaced and a couple other things. I'll post the list this evening when I get home from work.
yodawill2000
Car: 94 Infiniti J30
Tension Rod !!!Betcha a six pack .. lol
Look at the large bushing and see if its dry rotted
gr8scott72
Car: 1994 Infiniti J30t
95-j30t wrote:there is a noise that comes from the driver side tire when i go over bumps, it is a metal sound, i was thinking that it was the tie rod, so i replaced the driver side tie rod over the weekend, which improved the steering, but the sound is still there, any suggestions on what i should check thank you
It's deff. your sway bar bushings. You can get just the bushings from Infiniti for about $50 but you will have to have a way to press them in or you can get the entire bar with bushings in it already for about $150.
yodawill2000
When you say sway bar do you mean the tension rod ?Mine made a metal to metal sounding clunk when I hit a small bump and also if I got rolling a few miles an hour and stomped the brake pedal .Tension rod replaced and all is well .
gr8scott72
Yes, I belive we're talking about the same part.
yodawill2000
to add more confusion ..Joe at everythinginfiniti calls em tension struts Under 100 with the bushing
yodawill2000
Top right hand corner .. part #25
http://www.fuzzycats.com/j30parts/page_758.jpg
