kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Tue May 11, 2010 8:13 pm
Ok it seems like I've got another new noise developing, I'm really starting to believe my Rogue was built on a Friday afternoon before the long weekend.
So I'm getting what sounds like brake noise, but only under very precise circumstances:
Put the car into reverse first thing in the morning, start rolling backward, lightly apply brake pressure and hear a distinct "clunk", very loud and clear, sounds like pad-on-rotor noise to me. I continue rolling backwards and braking on/off and hear no noise, it only does it the first time I touch the brakes in reverse. If I stop, put the car in drive, roll forward lightly braking - no noise. Then put the car in Reverse again, roll backward and as soon as I lightly apply brake pressure I get the "clunk" again. Continue lightly braking in reverse, no additional noise.
Brakes are pretty quiet under all other driving conditions, except for the typical pad on rotor noises that you occaisionally expect. This noise seems to occur regardless if I turn the wheel or if I drive straight backward, I was starting to wonder if it was a front end component making the noise but turning the wheel doesn't seem to make a difference, and the clunk coincides exactly with the first application of the brake pedal when rolling in reverse. I can't explain why it only happens in reverse, and only the first time I apply the brakes after just staring out in reverse??!!
So what's everybody's best guess, bad caliper or rotor? I don't have time to take it in for a little while yet so I was interested in everyone's opinions, thanks.
