Noise - Turn Off Engine, Open Door, Click Click
All things Altima Coupe.
nascar9900
Symptoms: Drive car, stop, press Off to turn off engine. When I open the driver's door, it sounds like something electrical is being turned off in the instrument cluster. Two loud clicks.
Does anyone know what it is?
Happens on a 2008 Altima Coupe, 2.5, CVT with Convenience Package.
Does not occur on my 2010 Altima Sedan with 2.5, CVT, with Convenience Pkg and Conv Plus.
2008AltiCoupeDan
Car: 2008 Altima Coupe 2.5s - Gone, 2008 Subaru WRX Premium - built
its normal- its your door and security toggle switches engaging/disengaging :)
nascar9900
Thanks. I thought it might be something normal - but should I be concerned that it is so loud? And why doesn't it happen on the 2010 Altima Sedan? (No sound whatsoever. Do the later versions or the Sedan use a different design?)
srwong
Car: 2009 Altima Coupe 3.5 SE CVT
idk bout loud? i know after u turn off car, then open door. the start button makes a lil sound. but its because its recognizes that youre leaving the vehicle, n stats turning off sum stuff
insaneturbo13
Car: 2009 nissan a/c 2.5se red, medium tint, center console lights, ac vents, avic-u310bt, pioneer sub/amp 800 watts,
im pretty sure its the steering wheel lock, when it happens try turning the wheel, shouldnt move, if it does there is something wrong
srwong
insaneturbo13 wrote:im pretty sure its the steering wheel lock, when it happens try turning the wheel, shouldnt move, if it does there is something wrong
ah yes, thats it.. i havent been in the coupe today. so i couldnt remember correctly lol i remember seeing th esteering wheel turn a lil when i open door
nascar9900
Thanks. I checked it out and yes it is the steering wheel locking mechanism. I'm still under warranty, so will have the dealer check it out for the loudness.
If they say, "It's normal, they all do that." then I'll have the dealer explain why my 2010 Altima Sedan doesn't do it. I just checked and the sedan does not lock the steering wheel at all.
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
Also, after that click-click, you won't be able to manipulate your power windows/moonroof. Before opening your doors and after the car is off, you can still do that. So, if you plan on leaving them cracked for ventilation or closing them for rain, do that before you open the door.
Or before you turn off the car. But that's optional.
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
click click clack. thug life.
HelloImJarred
Car: 2009 Nissan Altima Coupe
Rmuth25 commin in off topic Screamin THUG LIFE!.. Get EM Modern Day 2PAC... I feel like slappin a nigga today... EM AND WAYNE - NO LOVE!!!
