Ahh, yes! That totally makes sense due to the mic the 14 speaker Bose system uses! I was thinking about that too!ken in az wrote:Depends on what stereo option you have. The non bose 5.1 system has the speed sensitive volume and the bose 5.1 system has the Bose Audio Pilot which senses the interior noise and adjusts volume up to match.
Ive tested it under the conditions you suggest and there is no difference. I'm not disappointed it doesn't work, in fact I would prob turn it off once I noticed it most likely. Plus, if i want to change the volume I have a thumb thats 0.1 inches away from the volume buttons on the wheel! Its just good to know that if you have a feature, it works regardless if you actually use it. I'm quite happy with my Mrsg123 wrote:You guys just need to find a very smooth to very rough highway transition. If the roads are fairly good in your area you might never notice the feature working.I'm kind of puzzled as to your disappointment that you can't notice Audiopilot working...you have a quiet luxury car. You should be happy.
Ed Zachly, mate ! It "compenstaes" it does NOT change the volume. Supposedly, it works the way the Bose noise-cancelling headsets work. It emits a noise-cancelling frequency to reduce ambient noise and thereby making the music, etc sound cleaner to be heard better. That said, I have no clue it it really does it or if it's working. When in doubt, turn it up !SmoovC wrote:From 4-17 in the 2012 Infiniti M Owner's Manual:
BOSE® AudioPilot® (if so equipped):
When this item is turned to ON, Audio-Pilot® 2 Noise Compensation Technology monitors noise in the passenger compartment with a microphone and compensates for any unpleasant noise.
... stands corrected. Thanks for that info, mate! That really IS unique for a car system. However I still prefer the Mark Levinson system in the LS460 but that's subjective and varies with each listener's ear holes, LOL.TDot wrote:It is not a noise canceling device or use phase cancelation. It doesn't adjust "volume" either in the simplest form. It adjusts eq based on the ambient noise to compensate for the noise, which is why theoretically you don't hear a tonal difference in the way it all sounds and the base, mids, highs sound relatively the same and why it's perceived to "raise the volume". This is why they market it as they do, because everyone/thing else does actual cancelation...they actually have something that is unque,
Shhhhh, don't you dare say that here!! I will have to agree with you whole heatedly and that will start a $#!t storm here lolLarz wrote:I still prefer the Mark Levinson system
Ban Larz lolTDot wrote:Shhhhh, don't you dare say that here!! I will have to agree with you whole heatedly and that will start a $#!t storm here lolLarz wrote:I still prefer the Mark Levinson system.
Yes, that is actually more correct, sir.TDot wrote:It is not a noise canceling device or use phase cancelation. It doesn't adjust "volume" either in the simplest form. It adjusts eq based on the ambient noise to compensate for the noise, which is why theoretically you don't hear a tonal difference in the way it all sounds and the base, mids, highs sound relatively the same and why it's perceived to "raise the volume". This is why they market it as they do, because everyone/thing else does actual cancelation...they actually have something that is unque,
