tortribune »
https://forums.nicoclub.com/tortribune-u98416.html
Wed Jun 04, 2008 6:20 am
So I'm having some noise and RPM issues.
To address the noise issue. Lately, when I am driving my car, it makes a grinding noise (almost like when you grind the gear) while accelerating and before the gear is switched. It only lasts a few seconds, but it happens almost every time before the gear is switched. A friend of mine said muffler, but it sounds like it's coming from the engine.
Also, it makes a loud whining noise when held at a constant RPM (driving) but when the car is braked the noise stops. A belt issue, maybe? Although, less then 5 months ago we replaced the belts and it ran fine until a few weeks ago.
The RPM issue is, when the car is started is sometimes runs at a high RPM (12-13) or an extremely low RPM (5ish, almost to the point of stalling out and it shakes like it's going to, so I'll give it some gas and hold the RPM's at a constant until I am moving.) I thought it might be a heat problem or a starter problem, so I was looking at getting either a new starter or a heat wrap or both.
Any suggestions would be great!
Thanks,Dana
