noise in rear
CusCo_S14
Car: 95 240SX se
I need verification.I drive a 95 S14 with Cusco susp. mods. When I start to move I get a creaking sound and this also happens when I go over speed bumps real slow I assume the sounds are coming from my rear subframe, if it is what would recommend to resolve this.
lsxavier
Car: 95 240sx se ka-t
I have the same problem. I just put a subframe collar for now and it works.I know its not going last forever but beats taking the whole subframe apart. It's a quick fix.
CusCo_S14
Car: 95 240SX se
which collars did you go? did you notice if any of the noise was reduced after install? how was the ride after install?
tetsuo
I've been fighting a creaking sound.. and it comes from the wall right under the rear side-glass on the driver side (its a 90 fastback). It's not where the glass fits in, but right beneath, where the plate holding the speaker screws into the frame.
All I've been able to do is pad it but still annoying, and tend to hear it more at slow speeds (only because high speeds mask it).
lsxavier
I bought the subframe collars from SPL Parts.You can buy it in ebay also.It's easy to put on and it eliminated the noise and wheel hop on my car.
tetsuo
ok I've seen the pics of the subframe collars, but where do these go into?
180fan
Car: 89 fastback
http://www.splparts.com/doc/Su...t.htm
I bought mine from SPL as well. Kuah is the man.
