TXT »
https://forums.nicoclub.com/txt-u206721.html
Tue Jun 24, 2014 3:47 pm
I'm getting an awkward noise coming from the front right wheel area after I installed my mid pipe...but that might not be related.
Anyways, when im going 65+ and my car hits a dip, as the car is moving downwards I hear a sound that sounds similar to the shield behind the rotors rubbing against the rotor itself. It's the same exact sound that would make. Only happens at higher speeds and only happens when the car's suspension is going in the downwards motion. My front wheels don't have that metal shield behind the rotors.
It happens seconds at a time so its never constant sound, only as the car is in the downwards motion after a dip on the highway...if that makes sense.
Also getting a weird rattling sound after I installed the mid pipe which should be related. Sounds like a thin metal rattling against another metal towards the back of the car, specifically above the mufflers. There is a heat shield above the mufflers so I believe that's the sound. This sound wasnt there before I installed the mid pipe. I had the Megan mufflers for about a year now and this sound was not there before I installed the mid pipe.
Anybody have these sounds before? Not too worried about it (except the front sound...might be wheel hub). It's mostly annoying.
These Jersey roads are messing up my car.
