Jimmy9190 »
https://forums.nicoclub.com/jimmy9190-u294982.html
Sat Nov 19, 2022 9:44 pm
I have a 2018 Rogue S, it has 52,000 miles on it. Lately I have been hearing an odd noise that sounds like it's in the dash somewhere. It's a howling type noise like a bad bearing or something rubbing where it should not be. It only happens with the AC on and I am stopped with the car in gear, like at a red light. Soon as I get moving again the noise is gone. It will also go away if I shift to neutral or park. I am looking for ideas on what it might be please. The AC works fine otherwise, it is ice cold with strong air flow. The car does not have the electronic climate control, just standard knobs you turn for the fan and temp settings.
Thanks for any help.
Jimmy
