Worn upper links will wear out the inner sides of the tires. They cost about $100/ea and are easy to replace.bigdog76 wrote:........that is what is causing the tire to wear on the inside for sure .
My experience is that worn upper links will eventually elongate the holes in the bracket it's mounted to and cause a squeaking noise. When you change links replace the bracket also if it shows signs of wear.bigdog76 wrote:......My 1996 O45 is making what seems to be a squeeking sound on the passenger tire wheel front well.........
Only 3? so the fourth is way down the road in wear relative to the other 3? How bizarre for that one axle!bigdog76 wrote:Replaced the struts 3 years agoBushing I have never done. Springs no
Must be the cambridge then!goody94q45 wrote:Brian- Your dislexia is acting up again. He replaced all the struts 3 years ago, not 3 struts years ago.
There is no y in Infiniti. It causes issues for maxnixmaxnix wrote:Those Infinity cars were always weird! Must be why we don't see very many of them on the road!
