The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Fri Feb 19, 2016 4:03 am
If it goes away when you turn off the AC, why do you suspect a tensioner? I would suspect the compressor. If it could be the tensioner, it could also be the water pump or alternator They all have bearings. That doesn't help narrow it down for you, but your options are figure it out yourself, trust the shop, or plan on throwing money at it until it's fixed. The figure it out yourself option makes me nervous, it involves using an automotive stethoscope (or a makeshift alternative for one [for instance, a 2x2 or thick stick of wood]) in order to determine where the sound is coming from. Incidentally, if you do that, you might check everything, especially in case the lower tensioner is also making a quieter noise that simply isn't catching your attention yet.
