Noise from amp question
All things Altima Coupe.
Rolling Estonian
Car: 2008 Altima Coupe 2.5
The last couple months I've been hearing this soft high pitched whir sound that goes up in pitch and loudness as the revs of the engine go up, such that at idle it's barely audible and at 4-5K rpm it's quite noticeable.
At first I thought it was something from my transmission, and had plans to have a mechanic look into it the next time I was at the dealership.
However I turned my head unit off while driving today and the whir stopped, radio back on whir is back. I'm now thinking it's related to my charging system and the current my alternator is putting out (higher engine revs faster the alternator spins, hence different sound at different rpm)
I have a 500W single channel and 400W 4 channel Rockford amps. I have a 4 gauge power wire, no big three upgrade yet.
Any one have a possible explanation.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Is this the stock HU or did you replace it with an aftermarket HU? Check the grounding!
Rolling Estonian
head unit is aftermarket. I'm going to check all the grounds when I get a chance.
billygg
Car: murano
this thread is a little old, but i am having the same issue with the factory HU and 5 channel amp.
Any ideas?
Thanks
