But like Dominick said, it's not a heat shield, but rather a hole after the cat. The reason I thought I could do it myself is that maybe if I just replace the entire segment, from junction to the other (since it is one continuous piece, right?). Obviously, if welding was the only approach, there's no way I could/would do it myself. But if I remove/replace the entire section of pipe (including the cat) isn't it just a matter of a few bolts, a few new gaskets, lining up the flanges, and bolting it in place?vocoder wrote:i had the same problem. especialy when i am accelerating or braking.what i did?
i bought mufler straps at "Murrays Auto Parts" around $3-$4and i did as show on picture.
blue color - holders that where all rusted and because that heat shield made noise while accelerating or braking.
brown color - strap that goes both around shield and catalytic converter (strap is a metal track full of holes) and i make it like a belt for jeans with screw (pink color).
its temoprary solution but it saves you 50 bucks at repair.
i hope it will help you
Modified by vocoder at 9:03 AM 6/27/2006
I think Dominick makes a point. Doing all those things yourself is not fun. I had the same issue. I took it to a shop and they replaced the converters with some aftermarket ones for about $220 including labour. He cut the old ones and welded the new ones. It took him about 40 minutes to complete. It's been about 2k5 miles and it's ok.DominickJ30 wrote:You wont be able to do this yourself unless you have a welder. And they were right, its not a heat shield but rather a hole probably right after the cat. I had the same thing with mine.
Best bet is to take it to a custom exhaust shop and either have them weld in a new pipe in that section, or get a whole new custom exhaust.
I think the tube size is either 2.25 or 2.5"
I think Dominic makes a point. Doing all those things yourself is not fun. I had the same issue. I took it to a shop and they replaced the converters with some aftermarket ones for about $220 including labour. He cut the old ones and welded the new ones. It took him about 40 minutes to complete. It's been about 2k5 miles and it's ok.DominickJ30 wrote:You wont be able to do this yourself unless you have a welder. And they were right, its not a heat shield but rather a hole probably right after the cat. I had the same thing with mine.
driverdriver wrote:Check everythinginfiniti, I would say the whole exhaust piece by piece is around 4000 dollars from the dealer. Try to tell me the exhaust shop would be more expensive.DominickJ30 wrote:
Quote »
A custom exhaust on the may cost you more than OEM. Get some quotes before you commit one way or another.
