noise coming from dash
duckhombre1
Car: 300 zx n/a
I have 1990 300z n/a it has a motorized noise coming from dash area/front of car i need to know if this is normal if not whats wrong with it.
NolimitZ32
Ive heard of this issue before I just can't remember what it was, try searching around because I'm positive there's a thread on it.
alright2020
Car: 92 jeep wrangler with SBC
99 F250 with 7.3 on 25lbs
91 300ZX na>tt>na
03 G35 coupe
when does it happen? possible like an ac mode door actuator if its an auto ac car....
duckhombre1
Car: 300 zx n/a
It happens at random times when the a/c is off
nissanfreak12
Car: 92 300zx 2+2 TT
There is a small fan where the map lights are, check that out. I had the same issue and swore it was from the dash, ended up being that little fan making a ton of noise. Disconnected and noise is gone.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
That fan in the map light assembly is the temperature sensor for the ACC (Automatic Climate Control.) If that is disconnected, the ACC will have inaccurate readings on interior temperatures and won't blow the right temperature air.
