gniknave wrote: Even though Wes told me what the HLA's are, I'm still not sure what that is (or maybe I do but don't know that's what it's called?).
The adjustors that you have slip the upper guides into, the Driver's side has the two studs/10MM nut and slides down into the hole from the top. The other bolts into the lower passenger side front of the block with 2 screws directly from the front (with the little hook). If you took them off then there is air trapped in them but goes away with a couple of starts.
Or you can yank the fuel pump fuse and crank it until you have oil pressure a few times, like Paul said above.
gniknave wrote:A question I have is, if the hydraulic tensioners aren't oiled, would that have caused the rpm to drop and sort of sputter (before I shut the car off)?
Homey says: "I don't think so!"
Did you disconnect the battery ?
