Noise @ ~2.7k+ RPM........
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
nick425
Car: 2008 Versa S
Ok so I have this noise that starts to happen at about 2.7k RPM on the 6speed manual. The best way to describe it is a static noise like on TV... Hard to explain. It happens in any gear at about 2.7k and then if I accelerate it stops or let off it stops. Its not a pinging noise and its not bad gas. I noticed it shortly after I began putting in Castrol Syntec 5W30 oil in it.... Took it to the dealer and he said its normal... It is kind of loud and very annoying because you hear it right as you shift and it is F#$&ING annoying! Please help! Thanks.
-Nick
NewToVersa
Got the same noise. Dont worry about it. Nothing you can do...
blkverssa7
Car: nissan versa hatchback 1.8L
me perrsonally i thin it has something to do with the accelorator cause you let off it stop you give it a little it goes ..... personally i think it has to do with it being so economically safe of some bs like that i hear the same thing ... hopefully they will make a recall on it and we will all get some free stuff haha
Return to “Versa Technical Discussions”
