Auto trans
I checked voltages on the white wire of the MAF, 1.7 at idle, 2.6-2.8 at 4000RPM. Obviously doesn't seem right. Cap, Rotor, Plus, Plug wires were all replaced when trying to troubleshoot this. I also cleaned the MAF with no luck.
I had a friend pull another MAF for me. Welp, said MAF did not work. Read 2.6-2.8v, again. So I went out and bought a brand new MAF, 2.6-2.8v at 4000 RPM. Engine grounds show continuity, TPS is checking out.
I checked the injectors, replaced the fuel filter, replaced the distributor cap, checked for vacuum/intake leaks, cleaned the IACV, regapped the plugs with note of signs of fouling due to unburnt fuel on all four plugs, also noted that timing was a few degrees off. Retimed the motor and set idle but still having issues.
Idle = misfire every 30 seconds - 1 minute
Press on the gas slightly = fine
Press on the gas 1/4-WOT = stumbles until 2500 RPM then takes off
Above 2500 RPM = Pulls nice and hard
Put in the new CTS and set timing again. No luck
Rev:
http://www.youtube.com/watch?v=E1wkDhEayQ8
Drive:
http://www.youtube.com/watch?v=y3CZraEsXmQ
The thing sounds like a Subaru when on the throttle until it gets going. I like the sound of a flat four, but not in this car, hah. Beginning to suspect a bad coil, but that's in the distributor since it's an s14, right? Ideas/Comments/Opinions? Really need some help here..
