Cliffo »
https://forums.nicoclub.com/cliffo-u234779.html
Thu Apr 17, 2014 3:53 pm
Hi All,
Got a '97 Hardbody D21; 4 cyl; 5-spd King Cab; orig owner; re-man'd motor; starts and idles just fine.
Problem:
P1130
No vacuum at Swirl Valve Control Solenoid Valve("C" nipple on solenoid to power actuator which tests good w/the Mity Vac).
I have a FSM on pdf and have gone through the test procedures w/o any success on why no vacuum to the brown solenoid to close the butterflies in the intake manifold to pass smog.
What I've tested: 12v @ swirl harness; all vacuum hoses are clear/connected correctly; steel tube "gallery" is clear; leak down test on vacuum tank; applied a hard 12v from a battery to the terminals of the brown solenoid & solenoid clicks(don't know about the current flow thru the solenoid(suspect?); CKP sensor is good; continuity test from ECU to Terminal 2 on solenoid harness is good; one way check valves are good.
Replaced: vacuum check switch; brown swirl valve solenoid
Still getting the P1130 code & swirl valves are still down under idle conditions as verified by the gold indicator rod on the valve assembly when looked at with my insp mirror. Truck also smokes when idling.
This is the last thing to fix before I can smog it and actually start driving it again!
Can anyone PLEEZ help?!
Thanks in Advance,
Cliff
