No Transmission Light Cluster.
zxFarside
Car: 94 300zx TT (sold)
03 Suburban 5.3
00 BMW 323
So my alternator went out (replacing it Saturday), and while it was failing it was making weird things happen to the transmission. I figured I would check to see if the trans was throwing any codes. I discovered that my car does not have a transmission display, or a display on the other side; they are just blank spots. Whats up with that? The car is a 94 TT.
https://ibb.co/4SGYLNr
https://ibb.co/6nmncTh
NolimitZ32
I believe those displays were only produced in 90 and 91, my 95 auto doesn't have it and my 92 started life as an auto and doesn't have it either.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
My 90 Canadian model has the left side blank too, no lights at all. Only the right rectangular screen and the bar just below the coolant temp gauge have indicator lamps.
