IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Sun Jan 18, 2004 5:38 pm
ok, first off, thats normal.
with the turbo you have alot more power than you did before.
changing gear ratios is not easy. you have to go to a different differential drive ratio, which affects all the gears, or change out first gear.
either one is not the solution to 1st gear traction issues.
secondly, your car is front wheel drive. when you accelerate, weight transfers to the rear wheels, and reduces the load on the front tires, which reduces their available traction. thats what makes RWD preferable in a performance oriented car.
thats just the way it is. get stickier tires or get used to it.
