InsanityInc wrote:Wrong graph. I think the one you're looking for is this one...
...This is the before/after cams/ecu graph. Unfortunately, since they added them both, it's kind of hard to determine what did what...
...The fact that the horsepower peak happens at the same RPM, and that adding an ECU and cams only raised the peak horsepower by 6 should probably tip you off to the fact that the cams aren't at fault.
No, that was exactly the graph I was looking for...
I wasn't trying to illustrate before/after with just cams....I was merely posting another dyno chart that showed TQ continuing past ~4300.
And it's easy to determine what did what...an ECU cannot increase top end airflow like that. It can maximize spark and fuel trim, which helps...but it's a linear increase...i.e. you'll gain 3-5rwhp across the board with an ECU. Same curve, just higher on the "y" axis. Similar to how pulleys "make" power...
Cams extend it out past it's previous drop-off spot.
And IMO, peak power means very little when compared with max gain...especially when you're looking at the effects of cams...the point of running hotter cams is to change the usable RPM range. So you increase airflow and upper-RPM torque, and that leads to more HP, and more usable revs...faster on the dragstrip, faster on a road course.
15.4rwhp is a HUGE gain...
Basically, more area under the curve makes a faster car...peak HP means nothing.
Anyway, we're starting to "beat a dead horse..."
We need some dyno evidence of a KA with a new/improved intake manifold to continue this debate...once you get it done, come back and show us what happened.
For now, lets agree to disagree.
- Brian
