matt4pl wrote:another alternative for setting timing is using consult or the PC-based conzult or w/e
Unless your pulley is some kind of freak, every OE and aftermarket 240SX pulley has timing marks. There's no other easy way to set ignition timing.
Can you see the pin that you use to match the marks up to?
Anyway, Consult is a great diagnostic tool but probably, IMO, overkill just to set your timing. It's still a great buy and you can get it from a NICO brother...
http://www.blazt.biz/index.php?dist=jerry
It's basically a slightly stripped down version of what Nissan techs use for about $2000 less. Just check to make sure you have a grey Consult port under the dash on the driver side.
