Carl H wrote:yay, good way to break a belt!then you can watch your engine destroy its self, its there for a reason after all.
+1 lol... Use washers on the rear of the hood to slightly raise it. Also adjust your hood latch release where the front of the hood hits it all the way up. See if that helps. Then remove the sheilding off the bottom of the hood...
last case senerio depending on where its hitting you might beable to remove a bit of metal from the hood.... I dont really recommend doing this.... but its worth a shot.
Last option get rid of the cross member and get an AM mount kit.
