evildky wrote:you're testing the wrong one, there are 2 sensors in the hard pipe, the one wiht 1 wire is actuallyt he temp sender, ti goes to the gauge in the dash and has nothign to do wht the ecu, the second one, has 2 wires and a plug that looks like an injector clip,
The one i was testing was the engine temp sensor that goes to the ECU. It has two wires going from the sensor and the clip but the pinout at the ecu only has the wire 28. There is no pin just a blank hole for sensor ground
is that how its supposed to be? Why is it stated in the diagram but does not appear on the harness at the ecu?
I replaced the sensor with a new one and replaced the clip with a new one. I reset the ecu for 30 min and its still throwing the code after I drive it. Car dumps fuel and revs like s*** after I start it again when warm, I have to drive it a bit for the idle to smooth out somewhat but it still smokes and smells.
Thanks for any help in advance guys
