brwolfe »
https://forums.nicoclub.com/brwolfe-u84189.html
Wed Dec 19, 2007 6:49 pm
I thought I noticed the temp gauge getting lower and lower on the dial, but it's now winter time here in the northeast, so I didn't think much of it.Now the gauge does not move at all.I tracked some of the posts on the forums to help me track down where it's even located.I found two sensors screwed into the manifold right after the radiator hose connection.The front one a single wire and the rear larger one has two wires.I take it the temp sensor is the single wire sensor.I removed the wire and cleaned and also measured 800 ohms from sensor to ground when the car was pretty warm yet.The local auto parts store wants $34 for a temp sensor, but I am not sure that's the problem. All the other gauges in teh dash are working, so I don's think it's a fuse, unless it has it's own, but nothing is marked so.
Any help would be appreciatted.
thanks
Brian.
