JZ90Q45 wrote:I did replaced the radio with a Panasonic radio. I have not replaced any light bulds. I tested every fuse with a voltage meter. The door switch and lights works fine. Over the weekend I thought I might have shorted by adding the radio. I removed the whole radio and it's the same problem. Do you know where is the tail light relay is located?
You've got some issues which are going to be difficult to solve on this message board. If you don't have a copy of the FSM you can download it for free at phatg20.net. YOu'll be going nowhere fast without this manual.
There's a lot of sensors and fuses tied into the two circuits you've described- Stoplamp switch, illumination switch, headlamp relay, stop and tail lamp sensor, etc. There's also a sensor activated by the brake pedaal that could be the problem. The stoplamp sensor you asked about looks like it might be in the trunk under the lock but not sure from the picture in the FSM. There's also a test procedure for this sensor on page EL-30.
Follow Brian's advice. Do a search in Infiniti Online Mechanic. I searched for Brake Light and got 4 good hits. Try different searchwords and you'll have a good idea of things you need to check. You'll get more useful information from the searches than we can offer you on this board. Good Luck.
