canadian booster »
https://forums.nicoclub.com/canadian-booster-u166668.html
Tue Jan 31, 2012 12:30 pm
i start my car up after 4 months of sitting, put the battery back in, no problem, fires up great, let her idle like 25 mins and shut it off.. oops, didn't close the drivers door all the way..
come back a couple days ago and the battery is dead from the inside light being on for a while. i put a charger on it, wait 4 hours and try to fire it up, turn the key and she fires up for about 3 seconds and then everything goes black.. so assuming it's the battery i go and mash the negative post coupler on there more, the lights come back, but now when i turn the key, RRrrRrRrRrrRrrr wont start :P
i'm gonna check the relays tonight and see if something blew. i'm at work right now with the negative line off the battery, hopefully that lets the computer reset.. last time this happened the only way to start her back up was a push start and pop the clutch, then everything was totally fine from then on .. hope that's not it because it's winter and i can't push anythign anywhere
