DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Fri Feb 03, 2012 9:34 pm
OK, hoping for a quick response or three before I turn it over to other hands...here we go...
I go to start the NA after it sat a few days after buying my TT in late December, and instead of firing hard and idling up like always it starts weakly and putters, then dies...and any and all future re-start attempts are futile.
The engine seems to have no compression or engine pulse, you can barely hear TDC as you crank the engine.
The exhaust smells very rich with gas fumes.
The car has a LOT of miles on it, but ran well before the current issue.
Test results:
1. Exhaust reeks of flowing fuel, and pulled spark plugs are wet with gas but not fouled- PERFECT gold/tan color and condition, but now wet.
2. PLENTY of power from 880CCA Megatron, all systems go (fuel pump makes it's noise, all lights/chimes/etc. except no check engine light?<found trying easy code pull>)
3. We have spark, proved removing coil and plug and grounding.
4. ECU code pull: 55
5. Pulled timing cover and verified cam gears/TB/crank in alignment with all marks at TDC
6. Ran compression test each cylinder and got very low but consistent readings, 75 PSI
Also to be considered are:
1. The car has the switched injector voltage mod
2. The car has an aftermarket alarm system that is not in use, but still resident and "active" although the remote does not have a battery, and alarm is not used. I noted the system is still active while trying the easy code pull as the unit is wired into the car at that location and has a LED light that blinked while I was in the area.
After spending the day under the advise of one of the BEST Z guys I know of (Cory/Rockchucker), albiet from his house/on the phone while I ran tests, this is the best I have- so I ran this all by my "normal" Z guy...who says bring it by, and I'll get it running for under $200!
WHAT AM I MISSING????
