satilla308 »
https://forums.nicoclub.com/satilla308-u194224.html
Fri Jan 20, 2012 6:11 pm
its finally running. played with the idle and its idling at about 800. it surges a little, only at idle tho and while driving it it shut off a couple of times while pressing the clutch and letting off the gas at 1500 or more rpms. when it doesnt shut off it will drop to about 500 rpms and climb back up to 800. still got a fuel temp sensor, air intake temp, and map/baro circuit code on my gst scanner. it has a crappy cone air filter. not the oem air cleaner. and have several exhaust leaks. so idk if i should look for a vacuum leak, focus on finding an oem air cleaner, or fix exhaust leak first. it drives great just small problem with the idle. any ideas?
