I'm having a problem getting a signal to the coils on my 04 sentra 1.8...
So here's what happened, my car always ran perfect I decided to replace the water pump and chain guides on it a few days ago. I drove the car in my garage replaced the parts (did not remove the chain so the timing stayed the same) finished the job and when I went to start it my battery got weak so I replaced it..After installing the new battery the car cranks perfect and gets gas but there is no spark. I've used a spark plug tester, test light, meter and no signal to the coils. All the fuses and relays are good, there is nothing unplugged or cut at all.
I'm hoping someone can help me and has a solution, or if someone has a wiring diagram so I can double check wires themselves.. thanks
