I think that my no start problem has been found ?
The mechs and I think it's the "cam angle sensor". With no help from codes stored or any other gizmos the guys did some simple checks using a "noid lite" and are fairly sure that sensor is the problem. The problem they duplicated was what happened to me at the outset. The car starts, runs for 2-3 seconds and dies. The noid lite fires one time and no more.
I agreed and ordered a new CAS from "Joe/Chris". Should be 390 bucks sent to me. Our local NAPA price is 425 plus taxes. The NAPA one is probably from the same source as the Infiniti's ?
I am curious if a CAS problem would show up if the car was hooked up to a Consult? Shouldn't there be a malfunction code displayed ?
For the unknowing, the Cam Angle Sensor acts as a distributor on the Q45. If anyone remembers what a distributor was and what it used to do? In fact it the CAS looks like a small distributor and is mechanically attaches to the end of the camshaft, at the front of the engine, left bank, through the valve cover.
The CAS on the Acura I have, is an electronic device that has no moving parts but has magnetic pick-ups.
http://www.AA1Car.com has excellent explainitions about car electronic systems.
RAP
