craigztoyz »
https://forums.nicoclub.com/craigztoyz-u86743.html
Tue Jul 15, 2008 7:41 pm
I have ecu out, and wiring, checking it all out, and thinking through it. I am not sure if ECu is turning on or not.
I can get it to start on ether spray, but thats it. Fuel pump is now shot, wont turn on when jumping it, so need info on the Walbro unit please.
I used a test light already on the fuel pump lead. It does not work, I did jump it to ground to trigger it, and had no pump on, even with power on white and orange wire(at connector) 2 other wires at the Z32 fuel pump connection of question are a thin orange and a thin blue. One is fuel gauge, is other fuel light?
I bypassed the fuel pump controller by connecting white,and oranges together there.
Things that work-all the car's b.s- lights, horn, stereo, fan....power at injectors, and coils, power at all ign hot and batt hot leads to ecu, start signal to ecu works, power at cas (do I know it works from the firing of cylinders?) How do the coils know when to fire? I assume not through ecu.
I am doing a few mods to my harness to make it fit better, and go in and out quickly and easily.
I wonder if I have no pulse due to no fuel presssure. I had it run before on a holey pump in a truck tank.
But ecu is not turning on trigger to fuel relay, and not to the coil/eccs relay. In Z32 it is a small orange wire at relay connector, and if I trigger it, then power to the idiot lights, and the car fires. Without, I forget, but think it did not. Late, been in wiring harness and long a$$ allstar game. bottom of the 15th right now.
