ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Sat May 24, 2008 9:44 pm
With the duty cycle going down, I would guess that it is the prime function like on my ecu, except mine does it in a different way (fires all injectors at the same time during the first revolution with a 1 second pulse). On another note though, I think .5% duty cycle is rather low, especially for trying to spray enough fuel to start a cold motor. When my SR is idling and fully warm with 72lb MSD injectors, i get around 2-3% duty (15.0 AFR). During cold start up, my duty starts in the range of 8% or so and slowly comes down as it warms.
Check your plugs and see if they are getting wet or fouled. If after a long cranking session without starting, they should at least seem damp. When I say damp, enough to give a light glaze reflection of light and not a river flowing out of the thing when you tip it. If not, then I say you are not spraying enough fuel to bring the ice princess to life. Mine became damp after I installed my C2DI ignition box and forgot to plug it in. I was cranking for about 10 seconds give or take. Pulled the plug to find out I wasn't getting spark and gave myself a tap on the back of the head when I saw the connector hanging there asking to be plugged in. Plugged it in and you know the rest.
I was not fortunate to have a working base map with my ECU when I first bought it. I started from scratch. The first thing I did was make a base running map, totally forgetting about cold starting the engine. I got impatient and found out the hard way when I went to try to start her up. So instead of leaning over and trying to figure out how to make a warm up map, fuel prime map, etc. Not only that, but I had no clue if I would be putting in too much or too little fuel. So I saved that part of the tuning for a rainy day. Instead, I repeatedly pumped my throttle while cranking it (yep, like a carb engine ) and let my acceleration enrichment/throttle pump maps do the work for me. When it started to sputter a little I continued to pump for a little more til it gave more of a chug, then find a happy spot in the throttle til it started. I also had to keep my foot on the throttle so it would not die until it warmed up a little.
Good thing though, I tuned a cold start map the next day and saved my compulsive stomping of the throttle for something more like forest fires .
