No start AGAIN
kibatheloanwolf
Car: 1987 D21 2.4L with a 5 speed manual trans
2010 Camry 2.5L with a 6 speed maunal trans
Well New starter new issues tried to start it at Walmart and the same thing happens Lights dim down and it clicks. But! There is a new symptom, This time The negative cable sparked and my whole truck died. I managed to kick start it and drove home but half way home..Electrical system dies then comes back on...
Any ideas at all?
RT22
Car: 1991 nissan hardbody
Check the grounds sounds like bad connection on ground to frame
Maverick7687
Car: Sagemist(FSO) 1998 Maxima SE & Charcoal Metallic(KG2) 1993 240sx & My newly aquired Pearl White 1990
If the ground on the battery sparked then it sounds like a bad battery connection. If you move it around everything should come back on. If lights are dimming and it's clicking, you may have a constant drain on the battery somewhere that is killing it. Make sure things like your brake lights aren't staying on..
FL.HBODY
Car: HARDBODY
if the ground is arcing when you go to connect it there is a draw on the battery system. the bigger the arc the more draw. should only be a very little one if you have a radio with clock or something like that, otherwise should be no arc, find the sourse of the draw on battery should solve prob.
kibatheloanwolf
Okay Ripped the old Battery cables out. The negative was so frayed it was sparking on the side of the engine and the positive fell apart when i took it off the battery. but Auto zone says new starter is dead so putting new cables in soon but i have to wait for a starter
RT22
Man sorry it killed new starter but sounds like you found the problem in the wires.
Maverick7687
Sounds like the cable was on its way out anyway. I agree with the arc thing though, didn't think about it but it makes sense.
kibatheloanwolf
Took it to a Napa parts store and had them install one...They cross threaded the top bolt halfway in and the bottom one looks good... Can it still run with the cross threaded top bolt?
seang
Car: Ford Fiesta ST
What bolt did they crossthread!?!?
kibatheloanwolf
Who Agrees this truck is an electrical nightmare?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
It can become a nitemare when unqualified places like NAPA put their hands on it.
kibatheloanwolf
Top one on the starter
A2V
When this kind of problem occurred in your vehicle there are two possible causes. It’s either something that involve your battery or something that involve your starter.
RT22
You really want a good connection and if it is cross threaded it is not good make them replace and redo it.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
If you're getting intermittent clicking, it means there's not enough battery juice to spin the starter, either due to a dying battery or insufficient connections. If the battery is good, another cause can be corrosion - that white flaky crap on the battery connections. It can also get down inside the cable insulation and rot through the wires. A loose ground explains the sudden dying. Follow your battery cable down to the frame and ensure the connection is tight and clean.
On the spark from the negative cable, are you certain you don't have anything crossed? Look for stripped/chaffed wires going to the positive side that may be making contact with the body or frame - that'll 'complete the circuit' and cause arcing.
Good luck.
kibatheloanwolf
Sigh... Any one who has rebuilt the NAP-Z engine...Please tell me how easy it is.
I seem to have blow my head gasket and my timing chain... Help
stagger
Sometimes when you take the starter off it needs to be cleaned where it mates on to the engine thats the ground and if not properly cleaned can cause a bad ground.Tony
