nevada7 »
https://forums.nicoclub.com/nevada7-u129372.html
Wed Mar 18, 2009 12:26 pm
Hello Everybody,I recently purchased a 1985 300zx non turbo 5 speed. the car had been stolen, having the ignition switch and steering wheel lock removed and destroyed. I hooked up a switch and button start system from the remaining wires(5).
I hooked up ACC, IGN, and (+) to a switch, and(+) and START. There is one wire(black with green stripe) that goes into the ignition switch harness(switch side) but does not have a corrosponding opposite(on the broken ignition switch contact plate its marked as "R")its not hooked up..
I now have all accessory lights, instrument lights, and a working starter.
One thing I notice, is in the on position, the battery dummy light does not light up. All others do.
Now fuel pump does not start, after bench testing, fuel pump is good.
Swapped ignition coil and ignition control module(ignitor?) into working 300zx, parts test fine, Tested primary side of coil, both wires have power going in, but not out.
Car is timed to TDC.
No lights on E.C.C.S. also no power at distributor wire harness.
Any help would be greatly appreciated, I have pictures available ande can take more. Thanks in Advance.
