tenkawa_akito wrote:Make sure the under dash plug is hooked up right (the one that is branched off teh ECU)
That part of the speedo circuit is at the end of the line.
Here is how the speedo circuit works:Two wires from the speed sensor - Yellow/Blue, and Yellow/BlackThey run to a connector called 211 that is a two wire gray connector.Next it should go to one connector in a set of three that is mounted on the frame rail, below the battery, called 202 for manuals. It has 8 wire ports (4 ports for the auto version). The wires are still the same color.
From there the wiring runs around the front of the car from passenger to driver side, then go back into the body behind the front left wheel. They go into M11 the Super Multiple Junction. Its the Huge white connector with 132 ports for wires, biggest connector in the car. It goes through the SMJ and into the gauge cluster where the wires Y off and one goes to the center plug, another goes to one of the side plugs (on a non HUD cluster).
After the wiring goes through the cluster the result is the Yellow/Green wire. This wire comes out of the cluster and heads straight to the ECU plug and on into the ECU.
The ECU is the last piece of electronics to get the speedo signal. That is why some say that if you cut the yellow green wire you will cut the speed limiter, because the ECU doesnt know how fast you are going. But the cluster will still read correctly. I dont know if this is true or not, never tried it.
