NolimitZ32 wrote:Its pretty rare for all coils to drop at once...
Agreed, so I'm doubtful it's the coils, but can't completely rule them out
NolimitZ32 wrote:...have you tested your PTU and CAS? Have a look at the FSM troubleshooting procedures, also if you have a Phase 2 PTU the testing procedure can be found in the sticky on the top of the tech forum.
I just tested the PTU from a set of procedures I found prior to your post, and it "seems" bad if I'm following the steps correctly and not getting the specified results, assuming those procedures are for the v2 PTU.
I'm not familiar with the "FSM troubleshooting procedures;" can you provide clarification and/or links?
Regarding the tech forum, I initially tried that in the early stages of my troubleshooting but the link brings me to an empty page. If there's something more that I'm missing, then that page is not designed very well to easily find the links in question. EDIT: I clicked on the wrong link (Tech Pages), and only just now saw the lower row of links and the one you mentioned (300ZXZ (Z32) Technical), and there in the stickies area was the S2 PTU test procedures, which is the same that I found elsewhere.
And I do have the dealer-recalled-and-installed black plastic-body PTU v2 with sub-harness. I'm the original owner and remember having to bring it in way back when...
NolimitZ32 wrote:Also if the car sat for a year was there a chance that some pesky rodents made their way into the wiring looms and had a feast, its rare but also happens.
Always a possibility, but I don't think that's the case in my situation as there's nothing I could find indicating any "eaten" wiring and all other electrical systems seem operable; just no spark.
