markd1037 »
https://forums.nicoclub.com/markd1037-u152770.html
Mon May 24, 2010 6:33 pm
Okay, after lots of testing I'm still not able to start my car.
The problem is that I have no spark. I have 12v and Ground at all the coil packs. I have checked continuity between the ECU and Power Transistor (PIN 1,2,3,11,20). I can feel the Ignition coil relay click on. Also I bought another Power Transistor from Ebay, guessing it would be that but I still have the same problem.
I have tested both Power Transistors units as described in the S13 Manual (page EF & EC 125) and neither one have any continuity. Maybe I have two bad ignitors???
Is there anything the ECU has to see before it can send spark. My O2 and detonation sensors are not connected, but I don't think they are required. Please help, any advice would be appreciated.
