You say you checked your ecu and got code 13, right? Did you search and see what that code is for? It is an extremely important code. One that will cause you all the headaches you're having. It means that your water temperature sensor plug (the one on the intake manifold closest to the rear of timing belt cover) is either not connected properly or the sensor has failed. Address this area and you should be just fine.swift240sx wrote:Ok so i reset my ecu and now its telling me no problems (before it was code #13)... but now im not getting any spark. so coilpack problem? spark plug problem? wiring problem (still? gotta be kidding me), what could be messing with spark?
Do you have the orange wire attached on the dash connector plug located to the right of the glove box. Your issues are in your wiring. Focus on your wiring job and I'm sure you'll be fine.swift240sx wrote:I dont get it. i get fuel and spark but my car still doesnt start!!!! what is it?? what else does a motor need to start????
If your harness had a melt down, then you got problems. Either you know how to repair your harness or replace it with another. The wiring is where most of you go wrong at and I do mean most. Some may get the engine to run and think they've scored a home run, but then disaster strikes when the engine stops running or doesn't run correctly which prompts these distress posts. I always say, take your time and follow simple instructions and if you don't think yo can handle it, be patient and find someone competent that can render you assistance.swift240sx wrote:thanks a lot. I guess ill wire it into the ecu. or at least wire it into the wires that go to the ecu. Well i checked the compression before i bought the car. it was all good. The car ran perfectly before the harness blew up and melted, so it cant be anything wrong with the engine mechanically. Its gotta be the wring. the only thing is that wiring is so messy and hard to diagnose whats wrong with so many different wires and whatnot. not gonna be fun. I cant see how my compression and timing could be off because of wring
