rioredstang »
https://forums.nicoclub.com/rioredstang-u121266.html
Sun Oct 25, 2009 2:22 pm
You need to take a test light and check for 12v at coil. Have someone crank engine over and test both wires, one will glow and the other should blink slightly. If it doesn't then you don't have trigger to coil. Your igniter could be bad. Check to make sure you have the right computer for a de motor. I don't think they are interchangeable. You say it floods out, then the injectors are working. This tells me the distributer is ok.
