No spark!
TheyCallMeDEE
Here's the deal, I've change out the dizzy because crank angle sensor went bad. Set the timing and all crank the car, boom everything good. It started up idle fine think everything was all good. It was getting late so I couldn't put the fan and fan shroud back on, waited a week later to put everything back on now the car won't start. It turn but won't start. Check fuse, ground and fuel, found out there was no spark. It's an s13 ka24de. Can anybody help me?
Roger_cha
Car: 91 nissan 240sx
check the coil to see if power coming from coil to dizzy.
TheyCallMeDEE
How do I do that bro?
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
pull 1 spark plug out..with the wire connected to that pulled spark plug..ground it out to the chasis and have a buddy crank the car over..if you see spark its good...if there is no spark..test the coil as the FSM shows..if you search this forum..you can find this test and many others .goos luck and keep us posted on your progress.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
grab a ohmmeter and test it out. check the resistance between the center terminal of the coil and a side terminal. Any of the two side terminals will do
