no spark
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
beeksur
I have replaced the coil and distributor but still have no spark from coil wire. Help. I have a 1978 Datsun 620 pickup, all original. It died then ran intermittantly before it finally died. I then tried the above fixes.
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
Welcome to the forum!
Look at your grounds!! They might be your problem.....test the continuity from the negative coil terminal to the chassy.
jeremy620
Car: 620 4x4
also check your ignition sswitch somtimes the loose fire on the start side
beeksur
The negative side of the coil shows power with the key on.
I'll check the ignition switch. Already checked for ground problems.
Thanks for your help.
Return to “Datsun 620”
