no spark
89sxcoupe
Car: 1989 240sx Coupe
car is a 89 coupe ka24eas the title says my car turns over but getting no spark.
short version:coil is good, getting power to coil, check fuses by batt. and ones by driver foot.
long version:i was driving my car the other day and the wiring harness that goes over the top of the raditor came loose and hit the fan and cut a gray wire inside that wire was a coated and non-coated wire. i spliced the 2 wires together and now the car turns over and no spark is comming out of the coil checked the fuses by the battery and the ones by the driver side kick panel. had the coil tested and its still good. unplugged the plug connented to the coil and there is power going in to the coil. is there any other hidden fuses or any thing?
tx for any help
Keen240sx
Car: 89 240sx
How do you know for sure its not getting spark? Did you check the fuses under the air box/intake filter?
89sxcoupe
i know its not getting spark ecouse i took the wire off the coil going to the distrib. and put it by the exhaust and no spark going off of it. i didnt see any fuses there i will have to check there i guess how big is the fuse box there?
Keen240sx
Car: 89 240sx
Yea sorry didnt read that close enough. The fuse box is the same size as the other one by the batt. Its right under the air box...
89sxcoupe
yea just checkd thoseall seemed good i guees it might be the igntion modeul on the coil brack is the only thing i can figure out is there any way to test it to see? i am not too good on all these electronis if it was a basic 350 chvey i could have had goingby now lol
