No Spark
imotion s14
Car: 1997 240SX
Engine cranks, I got fuel pressure, injectors pulsing, CAS works but i'm not getting any spark.
Been searching the forum for the past 3 weeks for a solution but everything I have read and tried hasn't fixed the issue.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Check your ignitor.The FSM has a procedure to check it.
Make sure you have good groundsThats what F'd me up.
If you don't have the FSM, then you suck.But... there's hope, you can find it in the FAQ section.
imotion s14
Car: 1997 240SX
well im gonna have to go thru it a 3rd time I guess.. but here is the weird thing. My tach pegs out with the key ON. It would go back down, then Every 8-10 seconds peg out.
imotion s14
Car: 1997 240SX
I'm getting power to the coils now but my tach is still jumping around. It's attempting to start but falls on it's face.
imotion s14
Car: 1997 240SX
I'm getting power now to the coils, but my tach is still jumping around like before. It's attempting to start but falls on it's face.
Modified by imotion s14 at 11:09 AM 5/30/2009
imotion s14
Car: 1997 240SX
IT'S ALIVE!!!!!!!!!!!!!!!!!11111
RB20DET_240SX
Car: 240SX 1990
how did you fix it then i am having the same problem
HowlerMonkey
Car: 1991 Infiniti M30 wi/ L28ET
A tach pegging like that is a classic symptom of a lifted ground somewhere whether a ground on the intake manifold or the negative battery terminal or a bad negative battery to body ground....etc.
